Thick-walled spherical pressure vessel
1 Objective
Verify Coreform IGA for Abaqus on a doubly curved three-dimensional problem whose solution is known exactly: a thick-walled sphere loaded by internal pressure. The Lamé closed-form solution gives the displacement and stress at every point in the structure, so the numerical solution is checked against exact values throughout the three-dimensional domain, and there is no separate reference solve to introduce its own approximation. The quantities of interest are the volume-integrated relative global \(L^2\) errors of the displacement vector, radial displacement, radial stress, and tangential stress.
2 Geometry
One octant of a hollow sphere with inner radius \(a\) and outer radius \(b\) is shown in Figure 1, with its dimensions provided in Table 1. The octant is oriented so the three cut faces lie on the coordinate planes. By spherical symmetry the octant with symmetry conditions represents the full sphere exactly.
Figure 1: Schematic of the thick-walled spherical shell octant and its coordinate-plane cut faces. The wall thickness is exaggerated for clarity.
Table 1: Geometric parameters.
Quantity Symbol Value
Inner radius \(a\) 0.9
Outer radius \(b\) 1
Wall thickness \(b - a\) 0.1
3 Material
The sphere is a homogeneous, isotropic, linear-elastic material (Table 2). The model is nondimensional: the modulus and pressure set the scale of the displacement solution but cancel from the relative-error metrics.
Table 2: Material properties.
Property Symbol Value
Young’s modulus \(E\) 1
Poisson’s ratio \(\nu\) 0
A uniform pressure \(p_i\) acts on the inner surface; the outer surface is traction-free (Table 3). The three cut faces carry symmetry conditions (zero normal displacement) on the \(x\), \(y\), and \(z\) coordinate planes, which restrain rigid-body motion and complete the octant model of the full sphere.
Table 3: Applied loading.
Inner pressure \(p_i\) \(1.00 \times 10^{-6}\)
Outer pressure \(p_o\) 0
5 Mesh & discretization
Coreform IGA discretizes the octant with immersed, trimmed U-splines: a structured rectilinear background grid is trimmed to the curved shell rather than body-fitting a mesh to it, so the spherical surfaces cut arbitrarily through the grid cells. The background element size is \(h = 0.1/2^{k}\) for refinement levels \(k = 0, 1, 2\), at degrees \(p = 1\), \(2\), and \(3\) with maximum continuity \(C^{p-1}\).
The accepted solution is the Lamé closed form for a thick-walled sphere under internal and external pressure [1]. With
\[ c = \frac{p_i a^3 - p_o b^3}{b^3 - a^3}, \qquad \kappa = \frac{(p_i - p_o)\, a^3 b^3}{b^3 - a^3}, \]
the radial and tangential stresses and the radial displacement are
\[ \sigma_{rr}(r) = c - \frac{\kappa}{r^3}, \qquad \sigma_{\theta\theta}(r) = c + \frac{\kappa}{2 r^3}, \qquad u_r(r) = \frac{1}{E}\left[(1 - 2\nu)\, c\, r + (1 + \nu)\, \frac{\kappa}{2 r^2}\right]. \]
The analytical reference is exact. On the represented trimmed domain, error integrals evaluated with the solver quadrature are compared with the acceptance limits: each refinement level carries its own relative \(L^2\) tolerance per quantity, tightening as the mesh refines (see the tolerance columns in the results table). No separate numerical reference solve is needed.
6.1 Global error evaluation
The default-off --quadrature-output option records physical reference positions X, reference volume weights dV, directly evaluated U, and frame-matched material S in the separate <job>_iga_quadrature.sql file (format version 1). Visualization remains in <job>_iga_results.sql (schema 5); L2 postprocessing needs only the quadrature file. Both cut and ordinary cells contribute. The postprocessor uses these solver samples to compute the L2 errors in global_l2_metrics.json. With \(\mathbf{n} = \mathbf{x}_q/\lVert\mathbf{x}_q\rVert\), it computes
\[ u_{r,h} = \mathbf{u}_h \cdot \mathbf{n}, \qquad \sigma_{rr,h} = \mathbf{n}^{T}\boldsymbol{\sigma}_h\mathbf{n}, \qquad \sigma_{\theta\theta,h} = \frac{\operatorname{tr}(\boldsymbol{\sigma}_h)-\sigma_{rr,h}}{2}. \]
For a scalar quantity \(q\), the reported relative global error is
\[ \epsilon_q = \frac{\lVert q_h-q\rVert_{L^2(\Omega)}}{\lVert q\rVert_{L^2(\Omega)}} \approx \left[ \frac{\sum_Q w_q\,\det(\mathbf{J}_q)\,[q_h(\mathbf{x}_q)-q(\mathbf{x}_q)]^2} {\sum_Q w_q\,\det(\mathbf{J}_q)\,q(\mathbf{x}_q)^2} \right]^{1/2}. \]
The vector-displacement error uses the Euclidean squared norm of \(\mathbf{u}_h-\mathbf{u}\) in the numerator and of \(\mathbf{u}\) in the denominator. The errors are integrated over the represented trimmed octant using the physical reference-volume weights. The results identify this domain as volume_quadrature_reference. The numerical integration uses the solver’s volume quadrature and does not independently bound quadrature error.
7 Results
7.1 Quantities of interest
For each mesh, the numerical fields for vector displacement, radial displacement, radial stress, and tangential stress are compared against the Lamé closed form in the relative global \(L^2\) norm. The error for each refinement level is shown beside the acceptance tolerance it is required to meet.
\(h\) Vector displacement error Tolerance Radial displacement error Tolerance Radial stress error Tolerance Tangential stress error Tolerance
0.1 \(0.584\%\) \(0.8\%\) \(0.568\%\) \(0.8\%\) \(28.5\%\) \(40\%\) \(1.89\%\) \(2.5\%\)
0.1 \(0.421\%\) \(0.6\%\) \(0.409\%\) \(0.6\%\) \(30.4\%\) \(45\%\) \(1.98\%\) \(2.8\%\)
0.1 \(0.418\%\) \(0.6\%\) \(0.405\%\) \(0.6\%\) \(30.4\%\) \(45\%\) \(1.98\%\) \(2.8\%\)
0.05 \(0.199\%\) \(0.3\%\) \(0.194\%\) \(0.3\%\) \(15.5\%\) \(20\%\) \(0.93\%\) \(1.2\%\)
0.025 \(0.0649\%\) \(0.1\%\) \(0.0632\%\) \(0.1\%\) \(7.78\%\) \(10\%\) \(0.437\%\) \(0.6\%\)
0.1 \(0.094\%\) \(0.1\%\) \(0.093\%\) \(0.1\%\) \(1.85\%\) \(2.5\%\) \(0.16\%\) \(0.2\%\)
0.05 \(0.0173\%\) \(0.025\%\) \(0.0166\%\) \(0.025\%\) \(0.681\%\) \(0.8\%\) \(0.0445\%\) \(0.06\%\)
0.025 \(0.00365\%\) \(0.005\%\) \(0.00312\%\) \(0.005\%\) \(0.211\%\) \(0.3\%\) \(0.0138\%\) \(0.02\%\)
0.1 \(0.0317\%\) \(0.05\%\) \(0.0287\%\) \(0.04\%\) \(0.837\%\) \(1.2\%\) \(0.0859\%\) \(0.12\%\)
0.05 \(0.00734\%\) \(0.01\%\) \(0.0064\%\) \(0.008\%\) \(0.207\%\) \(0.3\%\) \(0.0175\%\) \(0.025\%\)
0.025 \(0.00181\%\) \(0.0025\%\) \(404 \times 10^{-6}\%\) \(500 \times 10^{-6}\%\) \(0.0716\%\) \(0.1\%\) \(0.00588\%\) \(0.008\%\)
Download data (CSV)
7.2 Convergence
(a) Vector displacement \(\mathbf{u}\)
(b) Radial displacement \(u_r\)
(c) Radial stress \(\sigma_{rr}\)
(d) Tangential stress \(\sigma_{\theta\theta}\)
Figure 2: Relative global \(L^2\) error against the Lamé closed form under mesh refinement, per degree. Errors use the solver volume quadrature on the represented trimmed domain.
7.3 Contour plots
8 Performance
Performance is reported separately for trimming (building the trimmed U-spline basis on the immersing grid) and the Abaqus solve.
Coreform IGA Mesh
\(h\) Background Active Trimmed CPUs Wall-time [s]
\(0.1\) \(1{,}728\) \(343\) \(343\) \(1\) \(11.9\)
\(0.1\) \(1{,}728\) \(343\) \(343\) \(1\) \(40.6\)
\(0.1\) \(1{,}728\) \(343\) \(343\) \(1\) \(12.1\)
\(0.05\) \(10{,}648\) \(1{,}967\) \(1{,}963\) \(2\) \(47.4\)
\(0.025\) \(74{,}088\) \(12{,}460\) \(7{,}994\) \(4\) \(74.6\)
\(0.1\) \(2{,}744\) \(343\) \(343\) \(1\) \(23.4\)
\(0.05\) \(13{,}824\) \(1{,}967\) \(1{,}971\) \(2\) \(54.5\)
\(0.025\) \(85{,}184\) \(12{,}460\) \(8{,}003\) \(4\) \(87.4\)
\(0.1\) \(4{,}096\) \(343\) \(343\) \(1\) \(36.1\)
\(0.05\) \(17{,}576\) \(1{,}967\) \(1{,}961\) \(2\) \(139.5\)
\(0.025\) \(97{,}336\) \(12{,}460\) \(8{,}016\) \(4\) \(153.9\)
Download data (CSV)
Coreform IGA for Abaqus solve
\(h\) Elements Nodes DOFs Threads Wall-time [s]
\(0.1\) \(2{,}860\) \(2{,}195\) \(6{,}585\) \(1\) \(1\)
\(0.1\) \(6{,}818\) \(4{,}058\) \(12{,}174\) \(1\) \(4\)
\(0.1\) \(5{,}654\) \(3{,}278\) \(9{,}834\) \(1\) \(1\)
\(0.05\) \(11{,}960\) \(9{,}248\) \(27{,}744\) \(2\) \(5\)
\(0.025\) \(51{,}153\) \(40{,}266\) \(120{,}798\) \(4\) \(17\)
\(0.1\) \(2{,}889\) \(2{,}557\) \(7{,}671\) \(1\) \(3\)
\(0.05\) \(13{,}130\) \(11{,}040\) \(33{,}120\) \(2\) \(9\)
\(0.025\) \(56{,}962\) \(47{,}604\) \(142{,}812\) \(4\) \(20\)
\(0.1\) \(4{,}678\) \(3{,}958\) \(11{,}874\) \(1\) \(7\)
\(0.05\) \(19{,}971\) \(15{,}790\) \(47{,}370\) \(2\) \(38\)
\(0.025\) \(84{,}539\) \(66{,}267\) \(198{,}801\) \(4\) \(92\)
Download data (CSV)
9 Discussion
The \(p=1\), \(p=2\), and \(p=3\) cases converge monotonically toward the exact solution in all four global quantities. In this problem, the tangential stress is more accurate than the radial stress because it is dominated by the smoothly varying hoop response, while the radial stress must satisfy the traction boundary conditions at both surfaces, which cut arbitrarily through the immersed grid cells. However, these results do demonstrate that a curved geometry with a pressure-loaded surface that does not conform to the background grid can reproduce expected results. We note that the convergence rates do not meet the expected rates from finite element theory, but this is not surprising given the machinery required to integrate immersed IGA into Abaqus/Standard.
References
[1]
S. P. Timoshenko and J. N. Goodier, Theory of elasticity, 3rd ed. New York: McGraw-Hill, 1970.
Appendix
9.1 Capabilities exercised
The table is generated from current passing simulation and study artifacts. Each row must satisfy the linked capability card’s evidence contract; declaring a capability in a test does not, by itself, create evidence.
Table 4: Capabilities exercised by the current verification artifacts.
Capability Evidence level
Linear static analysis Numerically validated
Static stress analysis Numerically validated
Cartesian symmetry boundary conditions (X, Y, Z) Numerically validated
Boundary conditions and constraints Numerically validated
Threaded Abaqus/Standard execution Numerically validated
Parallel Coreform IGA mesh generation Numerically validated
Parallel execution Numerically validated
Pressure loading Numerically validated
Uniform pressure loading Numerically validated
Mechanical loads Numerically validated
Linear elastic material behavior Numerically validated
Materials and section assignments Numerically validated
Meshing Numerically validated
Linear C0 spline basis Numerically validated
Quadratic C1 spline basis Numerically validated
Cubic C2 spline basis Numerically validated
Immersed rectilinear meshes Numerically validated
Spline basis degree and continuity Numerically validated
Explicit field-output selection Numerically validated
Field output requests Numerically validated
Stress field output (S) Exercised
Displacement field output (U) Numerically validated
Individual field-output variables Numerically validated
Dependent part instances Numerically validated
9.2 Download artifacts
9.2.1 Geometry CAD files
No separate CAD file is required for this problem; the geometry is fully defined in the Abaqus/CAE journal files.
9.2.2 Abaqus/CAE journal files
11 generated Abaqus/CAE journals are available.
Show 11 individual journals
9.3 Supported Abaqus keywords
The deck below is reproduced from the verification test’s Abaqus input file with comments stripped and instance-specific names (sets, materials, files) redacted to <placeholders>.
*Heading
*Preprint, echo=NO, model=NO, history=NO, contact=NO
*Include, input=<iga-mesh-inp>
*System
*Material, name=<material>
*Elastic
1.,0.
*User Output Variables
1,
*Boundary
<node-set>, XSYMM
*Boundary
<node-set>, YSYMM
*Boundary
<node-set>, ZSYMM
*Step, name=<step>, nlgeom=NO, inc=1
*Static, direct
1., 1.,
*Restart, write, frequency=0
*Output, field
*Node Output
U,
*Element Output, position=AVERAGED AT NODES, directions=YES
S,
*Node Output
U
*Output, history, variable=PRESELECT
*End Step
9.4 Provenance
The records below identify the execution environment and verification basis for every CTest artifact reported on this page.
Parameter Value
Evidence type Numerical verification
CTest result Passed (Release)
Verification result Passed — 4/4 enforced criteria passed
Test date 04-Nov-2026 19:37:30
Operating system Ubuntu 24.04.5 LTS
Coreform IGA version 2026.11+72575
Source revision e48e5098b2f8
Abaqus version Abaqus 6.26-4
Parameter Value
Test date 04-Nov-2026 19:17:39
Parameter Value
Test date 04-Nov-2026 19:38:15
Parameter Value
Test date 04-Nov-2026 19:22:50
Parameter Value
Test date 04-Nov-2026 19:21:49
Parameter Value
Test date 04-Nov-2026 19:24:21
Parameter Value
Test date 04-Nov-2026 19:24:24
Parameter Value
Test date 04-Nov-2026 19:20:09
Parameter Value
Test date 04-Nov-2026 19:20:23
Parameter Value
Test date 04-Nov-2026 19:24:58
Parameter Value
Test date 04-Nov-2026 19:18:13
Parameter Value
Test date 04-Nov-2026 19:41:04 UTC
Operating system —
Coreform IGA version Not applicable — postprocessing-only CTest
Abaqus version Not applicable — postprocessing-only CTest
Parameter Value
Operating system —
Parameter Value
Test date 04-Nov-2026 19:41:03 UTC
Operating system —
