Random response analysis
Compute power spectral densities, RMS values, and RMS von Mises stress from an Abaqus frequency extraction.
Random response analysis predicts how a structure answers an excitation that can only be described statistically, such as road roughness, jet noise, or a vibration qualification test. The loading is given as a power spectral density rather than a time history, and the results are spectral densities and root mean square values rather than peaks.
This matters more for Coreform IGA for Abaqus than for a native model. Coreform IGA meshes are Abaqus user elements, and Abaqus/Standard does not post-process a random response for them. For an IGA model the frequency extraction is all the solver provides, so the random response has to be computed afterwards from the modal data. The respspec utility does that, using the same procedure Abaqus applies to native elements.
1 What the utility computes
The excitation is a cross-spectral density matrix projected onto the modes. For base motion this follows directly from the participation factors:
\[ S^f_{\alpha\beta}(f) = \sum_J g_J^2 P^J(f) \sum_i \sum_j \Gamma^i_\alpha \Gamma^j_\beta \sum_I \Psi^{IJ}_{ij} (2\pi f)^{2\lambda_I} \]
Each mode then responds through its complex transfer function \(H_\alpha\), giving the cross-spectral density of the generalized coordinates, and the physical result follows from the mode shapes:
\[ S^q_{\alpha\beta}(f) = H_\alpha \, S^f_{\alpha\beta}(f) \, H^*_\beta \qquad S^u_{NN}(f) = \phi^N_\alpha \, S^q_{\alpha\beta}(f) \, \phi^N_\beta \]
Velocity and acceleration spectral densities carry factors of \((2\pi f)^2\) and \((2\pi f)^4\). Every RMS value is the square root of its spectral density integrated across the frequency range by the trapezoidal rule, over exactly the frequency points Abaqus would have used.
2 RMS von Mises stress
Von Mises stress is a quadratic form in the stress components, so its RMS cannot be recovered from the RMS of the individual components. The utility uses the method of Segalman et al., which is what Abaqus uses for the same variable. Writing \(T_{\alpha\beta} = \psi_\alpha^\mathsf{T} A \, \psi_\beta\) for the modal stress vectors \(\psi\) and the constant matrix \(A\) of the invariant:
\[ \text{RMISES} = \sqrt{\sum_\alpha \sum_\beta V_{\alpha\beta} \, T_{\alpha\beta}} \]
where \(V_{\alpha\beta}\) is the variance matrix of the generalized coordinates.
Do not form von Mises stress from RMS stress components. RMS values are unsigned, so a component that should cancel against another instead adds. On the validation models this route is wrong by up to a factor of three.
3 Running an analysis
The workflow matches the response spectrum walkthrough. Extract once, then run as many cases as you like.
export RESPONSE_SPECTRUM_DIR=/path/to/cf/interop/abaqus/response_spectrum
export PYTHONPATH="$RESPONSE_SPECTRUM_DIR"
abaqus python -m respspec extract myjob.odb myjob_modal.npz --fields U,S
python3 -m respspec random myjob_modal.npz mycase.json myjob_rms.npz --fields U,V,A,S
The results are RU, RV, RA, and RS, one RMS value per component, plus RMISES when the frequency step wrote stress mode shapes. Read them exactly as the peak results are read, through load_peak_fields_npz.
4 The case file
A random response case file describes the frequency functions, the base motions, the correlation between them, the sweep, and the modal damping.
  "psds": {
    "QUAL_TEST": {
      "type": "BASE",
      "gravity": 9.81,
      "rows": [[0.01, 0.0, 20.0], [0.04, 0.0, 200.0], [0.01, 0.0, 2000.0]]
  "base_motions": [
    {"dof": 1, "load_case": 1, "kind": "ACCELERATION"},
    {"dof": 2, "load_case": 1, "kind": "ACCELERATION"}
  "correlations": [
    {"psd": "QUAL_TEST", "type": "UNCORRELATED", "weights": {"1": [1.0, 0.0]}}
  "lower_frequency_hz": 20.0,
  "upper_frequency_hz": 2000.0,
  "n_points": 20,
  "bias": 3.0,
  "frequency_scale": "LOGARITHMIC",
  "damping": 0.05
Frequency functions. Each row of a psds entry is a real part, an imaginary part, and a frequency in cycles per time, matching *PSD-DEFINITION data lines. Values are interpolated log-log in frequency and held constant outside the table. Type BASE needs a gravity value and its ordinates are in g units squared per frequency; FORCE is in power units; DB takes decibels against a db_reference with band numbers 1 to 15 in place of frequencies.
Base motions. Each entry is a degree of freedom from 1 to 6, a load case number, and a spectrum kind of ACCELERATION, VELOCITY, or DISPLACEMENT. All base motions in one load case must share a kind. Only the primary base is supported.
Correlations. A correlation ties one frequency function to one or more load cases with complex weights, written as real and imaginary pairs. Type CORRELATED makes every pair of degrees of freedom in the load case fully dependent, so their participation factors add before the outer product. Type UNCORRELATED keeps only the diagonal, so the contributions add in squares.
The sweep. The range is divided at every eigenfrequency inside it, and each interval receives n_points points placed by the Abaqus bias formula. A bias above 1 clusters points toward the eigenfrequencies at the interval ends, where the response varies fastest. The default of 20 points and a bias of 3 matches Abaqus. RMS values are only as accurate as this integration, so increase n_points if the result has not settled.
5 Limitations
Only base motion excitation is implemented. Concentrated, distributed, and connector loads, moving noise correlations, and the UPSD and UCORR user subroutines are not. Secondary bases are not supported, matching the restriction that a random response step has only a primary base.
6 Verification
The same three steel solids used for the response spectrum work carry six random response steps each, covering one and three excitation directions, correlated and uncorrelated loading, two superposed load cases, a displacement base spectrum, and both frequency scales. Recombining the extracted modes in Python reproduces the Abaqus values for RU, RV, RA, RS, and RMISES to within a relative error of about \(200 \times 10^{-9}\) of the peak, which is the precision of the single-precision fields Abaqus writes. The generated sweep matches Abaqus point for point.
Independently of Abaqus, the single degree of freedom response to white noise is checked against its closed form, \(\sigma^2 = S_0 / (8 \xi \omega_0^3)\), and the agreement is shown to improve as the number of frequency points rises.
