NAFEMS P18 T4: two-dimensional heat transfer with convection
1 Objective
Verify two-dimensional steady conduction with convection boundaries using Test T4 of The Standard NAFEMS Benchmarks [1]. The study compares a body-fitted Coreform/Abaqus IGA solution with the published target.
2 Geometry
The domain is \(0.6\ \text{m}\) wide, \(1.0\ \text{m}\) high, and \(0.05\ \text{m}\) thick. Point E is located at \((x,y)=(0.6,0.2)\ \text{m}\). Insulated front and back faces preserve the two-dimensional response.
3 Material
The isotropic thermal conductivity is \(k=52\ \text{W}/(\text{m K})\).
The bottom edge AB is held at \(100\ ^\circ\text{C}\), and the left edge AD is insulated. The top and right edges exchange heat with a \(0\ ^\circ\text{C}\) environment using \(h=750\ \text{W}/(\text{m}^2\text{K})\).
5 Mesh & discretization
The Coreform/Abaqus model uses a body-fitted \(12\times20\times1\) mesh with linear, \(C^0\) splines.
The accepted temperature at E is \(18.3\ ^\circ\text{C}\) [1]. The automated Coreform/Abaqus test enforces a 3% relative-error limit.
7 Results
7.1 Temperature at point E
| Discretization | \(T_E\) (\(^\circ\)C) | Relative error | Limit |
| Body-fitted Coreform/Abaqus IGA | 18.08995 | 1.148% | 3% |
8 Discussion
The result satisfies the published target and verifies steady two-dimensional conduction and convection on a body-fitted spline discretization.
References
Appendix
8.1 Download artifacts
8.1.1 Geometry CAD files
8.1.2 Abaqus/CAE journal files
1 generated Abaqus/CAE journal is available.
Show 1 individual journal
8.2 Provenance
The record below identifies the Coreform/Abaqus verification evidence used by this page.
| Parameter | Value |
| Evidence type | Numerical verification |
| CTest result | Passed (Release) |
| Verification result | Passed — 1/1 enforced criterion passed |
| Test date | 04-Nov-2026 19:40:18 |
| Operating system | Ubuntu 24.04.5 LTS |
| Coreform IGA version | 2026.11+72575 |
| Source revision | e48e5098b2f8 |
| Abaqus version | Abaqus 6.26-4 |
