Cantilever beam shock and vibration
1 Objective
Verify mode-based linear dynamics on a cantilever beam: a frequency extraction, a random response to a base-acceleration power spectral density, and a peak response to a base-acceleration shock spectrum.
Coreform IGA elements are Abaqus user elements. Abaqus/Standard will extract eigenmodes for them, but it does not post-process a random response or a response spectrum from those elements, so for an immersed model the frequency extraction is the last result the solver produces. Coreform computes the two remaining procedures from that modal basis instead.
That arrangement has two things to verify, and this study checks both.
  1. The implementation. On the body-fitted mesh Abaqus computes all three steps itself, so the Coreform random response and response spectrum can be compared against the solver’s own answers on an identical modal basis. Any difference here is implementation error alone.
  2. The discretization. The immersed Coreform IGA modal basis, post-processed by Coreform, is compared against the body-fitted Abaqus analysis end to end. Any difference here is the difference between two meshes.
2 Geometry
Table 1: Cantilever beam geometry.
Parameter Value
Width \(b\) \(0.1\ m\)
Height \(h\) \(0.1\ m\)
Length \(L\) \(1\ m\)
The beam is the same one used by the static cantilever beam bending study, so the two chapters describe one physical beam under different analyses. The section is square, which makes every bending mode a degenerate pair and puts a torsional mode inside the analysis band.
3 Material
Table 2: Linear elastic material.
Property Value
Young’s modulus \(E\) \(200 \times 10^{9}\ Pa\)
Poisson’s ratio \(\nu\) 0
Mass density \(\rho\) \(8.00 \times 10^{3}\ kg/m^3^\)
Poisson’s ratio is zero so that the three-dimensional solid reproduces the one-dimensional beam theory the accepted frequencies come from.
The root face at \(z = 0\) is fully clamped. Both dynamic steps excite the structure through a primary base motion in the global \(y\) direction, the weak bending direction of the section.
Table 3: Excitation and analysis settings, shared by both discretizations.
Quantity Value
Analysis band \(10\ Hz\) to \(2.00 \times 10^{3}\ Hz\)
Modes extracted \(20\)
Modal damping \(\xi\) 20.0 ^{-3}
Base acceleration PSD 10.0 ^{-3} g²/Hz, flat
Frequency points per interval \(20\)
Bias parameter 3
Modal summation SRSS
The random response is driven by a flat base-acceleration spectral density across the band, the shape a vibration qualification test specifies. The response spectrum is driven by a base-acceleration shock spectrum that rises to a plateau and rolls off.
Table 4: Base-acceleration shock spectrum, tabulated at the modal damping ratio.
Magnitude (m/s²) Frequency (Hz)
20 10
200 100
200 600
60 2.00 ^{3}
5 Mesh & discretization
Two discretizations of the same beam. The body-fitted case is a structured C3D8 mesh that Abaqus owns end to end. The immersed case is a Coreform IGA mesh on a rectilinear background grid, trimmed to the beam.
Table 5: Discretizations compared.
Case Discretization Element size Dynamics computed by
abaqus_h0p1 Body-fitted Abaqus (C3D8) \(50.0 \times 10^{-3}\ m\) Abaqus/Standard
immersed_h0p1 Immersed Coreform IGA \(25.0 \times 10^{-3}\ m\) Coreform, from the modal basis
The immersed case uses a finer background cell than the body-fitted element size. A linear immersed basis needs four cells across the section to resolve bending; at two cells the fundamental frequency comes out several percent stiff.
The fundamental bending frequency of a clamped-free Euler-Bernoulli beam is
\[ f_1 = \frac{\beta_1^2}{2 \pi L^2} \sqrt{\frac{E I}{\rho A}}, \qquad \beta_1 = 1.8751 \]
with \(I = b h^3 / 12\) the second moment of area and \(A = b h\) the cross-sectional area. A three-dimensional solid sits slightly above this value because beam theory omits shear flexibility.
The random response and response spectrum quantities have no closed form, so the body-fitted Abaqus analysis is the accepted reference for them. Because Abaqus also computes both procedures on the body-fitted modal basis, the Coreform implementations are additionally checked against the solver directly, which is a stronger statement than the mesh comparison.
7 Results
7.1 Implementation against Abaqus
On a given modal basis the Coreform procedures and Abaqus solve the same problem, so they must agree to solver precision. Abaqus produces displacement-based dynamics output even for user elements, so this comparison is available on both discretizations.
The reported quantity is the component the base motion excites, which is what this chapter’s results are about and the only component whose magnitude is set by the excitation rather than by cross-coupling.
Table 6: Coreform against Abaqus/Standard on an identical modal basis, worst relative difference in the excited component. Accepted below 5.00 ^{-6}, and the immersed error is additionally required to stay within 4 times the body-fitted one.
Procedure Body-fitted Immersed Ratio
Random response 212 ^{-9} 213 ^{-9} 1
Response spectrum 97.1 ^{-9} 121 ^{-9} 1.25
Download data (CSV)
Both discretizations agree with the solver at the precision of the single-precision fields Abaqus writes, and they agree with each other: the immersed modal basis costs the implementation nothing. That parity is asserted by the study rather than left to the reader, because it is the claim that lets the immersed workflow stand in for a solver-computed one.
Judging the whole displacement field instead would let a small secondary component decide the number. The axial component here peaks near eight percent of the field peak, so points that clear a field-wide floor still sit in that component’s own round-off, and the worst of them grows with however many output points a mesh happens to carry. The immersed mesh has roughly eight times as many output points as the body-fitted one, which on a field-wide measure inflates its figure to around \(1.4 \times 10^{-6}\) while the excited component stays at \(210 \times 10^{-9}\) on both. The field-wide numbers are recorded in the downloadable data for transparency, but nothing is gated on them.
7.2 Eigenfrequencies
Table 7: Eigenfrequencies of the two discretizations, with the participation factor in the excitation direction. A mode participates when its factor reaches 1% of the largest.
Mode Body-fitted (Hz) Immersed (Hz) Relative difference \(|\Gamma_y|\) Participating
\(1\) 81.6 81.8 2.10 ^{-3} 0.116 yes
\(2\) 81.6 81.8 2.25 ^{-3} 6.99 yes
\(3\) 492 494 5.20 ^{-3} 0.2 yes
\(4\) 492 494 5.50 ^{-3} 3.89 yes
\(5\) 722 822 0.139 816 ^{-15} no
\(6\) 1.25 ^{3} 1.25 ^{3} 292 ^{-6} 31.4 ^{-15} no
\(7\) 1.30 ^{3} 1.32 ^{3} 8.46 ^{-3} 9.96 ^{-3} no
\(8\) 1.30 ^{3} 1.32 ^{3} 8.75 ^{-3} 2.29 yes
Download data (CSV)
Against the closed form, the body-fitted mesh gives \(81\.6\\\\\\\\ Hz\) and the immersed mesh \(81\.8\\\\\\\\ Hz\), where Euler-Bernoulli theory predicts \(80\.8\\\\\\\\ Hz\). Both sit above the beam-theory value, as a shear-flexible solid should.
7.3 Response
Table 8: Peak response in the excitation direction, body-fitted Abaqus against immersed Coreform. Accepted below 50.0 ^{-3}.
Quantity Body-fitted Abaqus Immersed Coreform Relative difference
RMS displacement, random response \(340 \times 10^{-6}\ m\) \(346 \times 10^{-6}\ m\) 17.9 ^{-3}
Peak displacement, shock spectrum \(965 \times 10^{-6}\ m\) \(983 \times 10^{-6}\ m\) 18.3 ^{-3}
Download data (CSV)
8 Discussion
The two halves of the arrangement behave differently, and separating them is the point of this study.
The implementation is exact to solver precision. Given the same modal basis, the Coreform random response and response spectrum reproduce Abaqus to a few parts in ten million, which is the precision at which Abaqus stores its fields. Nothing in the combination introduces error.
The discretizations differ by the amount two meshes differ. The participating eigenfrequencies agree to under one percent, and the RMS and peak responses to under two percent, on a comparison between a body-fitted linear hexahedral mesh and a trimmed immersed spline basis.
Not every mode needs to agree for the response to agree. The square section puts a torsional mode inside the analysis band, and a linear immersed basis represents torsional warping far less accurately than bending: that mode is stiff by an order of ten percent. It carries no participation in a transverse base motion, so it never reaches the response, and the study gates on the participating modes for that reason. The full spectrum is tabulated above so the departure is visible rather than hidden, and it is a useful reminder that agreement mode by mode is neither necessary nor sufficient for agreement in the response.
RMS values depend on the frequency sweep. The random response integrates a spectral density that is sharply peaked at lightly damped resonances, so the reported RMS is only as converged as the sweep beneath it. At the settings used here both codes integrate the same points and agree with each other, but neither is the converged integral. A production run should raise the number of points per interval until the RMS stops moving.
9 References
10 Appendix
10.1 Capabilities exercised
No qualifying capability evidence was generated for these run artifacts.
10.2 Supported Abaqus keywords
*Heading
*Preprint, echo=NO, model=NO, history=NO, contact=NO
*Part, name=<part>
*Node
      1,  0.100000001,  0.100000001,           1.
      2,  0.100000001, 0.0500000007,           1.
      3,  0.100000001,           0.,           1.
      4,  0.100000001,  0.100000001,  0.949999988
      5,  0.100000001, 0.0500000007,  0.949999988
      6,  0.100000001,           0.,  0.949999988
      7,  0.100000001,  0.100000001,  0.899999976
      8,  0.100000001, 0.0500000007,  0.899999976
      9,  0.100000001,           0.,  0.899999976
     10,  0.100000001,  0.100000001,  0.850000024
     11,  0.100000001, 0.0500000007,  0.850000024
     12,  0.100000001,           0.,  0.850000024
     13,  0.100000001,  0.100000001,  0.800000012
     14,  0.100000001, 0.0500000007,  0.800000012
     15,  0.100000001,           0.,  0.800000012
     16,  0.100000001,  0.100000001,         0.75
     17,  0.100000001, 0.0500000007,         0.75
     18,  0.100000001,           0.,         0.75
     19,  0.100000001,  0.100000001,  0.699999988
     20,  0.100000001, 0.0500000007,  0.699999988
     21,  0.100000001,           0.,  0.699999988
     22,  0.100000001,  0.100000001,  0.649999976
     23,  0.100000001, 0.0500000007,  0.649999976
     24,  0.100000001,           0.,  0.649999976
     25,  0.100000001,  0.100000001,  0.600000024
     26,  0.100000001, 0.0500000007,  0.600000024
     27,  0.100000001,           0.,  0.600000024
     28,  0.100000001,  0.100000001,  0.550000012
     29,  0.100000001, 0.0500000007,  0.550000012
     30,  0.100000001,           0.,  0.550000012
     31,  0.100000001,  0.100000001,          0.5
     32,  0.100000001, 0.0500000007,          0.5
     33,  0.100000001,           0.,          0.5
     34,  0.100000001,  0.100000001,  0.449999988
     35,  0.100000001, 0.0500000007,  0.449999988
     36,  0.100000001,           0.,  0.449999988
     37,  0.100000001,  0.100000001,  0.400000006
     38,  0.100000001, 0.0500000007,  0.400000006
     39,  0.100000001,           0.,  0.400000006
     40,  0.100000001,  0.100000001,  0.349999994
     41,  0.100000001, 0.0500000007,  0.349999994
     42,  0.100000001,           0.,  0.349999994
     43,  0.100000001,  0.100000001,  0.300000012
     44,  0.100000001, 0.0500000007,  0.300000012
     45,  0.100000001,           0.,  0.300000012
     46,  0.100000001,  0.100000001,         0.25
     47,  0.100000001, 0.0500000007,         0.25
     48,  0.100000001,           0.,         0.25
     49,  0.100000001,  0.100000001,  0.200000003
     50,  0.100000001, 0.0500000007,  0.200000003
     51,  0.100000001,           0.,  0.200000003
     52,  0.100000001,  0.100000001,  0.150000006
     53,  0.100000001, 0.0500000007,  0.150000006
     54,  0.100000001,           0.,  0.150000006
     55,  0.100000001,  0.100000001,  0.100000001
     56,  0.100000001, 0.0500000007,  0.100000001
     57,  0.100000001,           0.,  0.100000001
     58,  0.100000001,  0.100000001, 0.0500000007
     59,  0.100000001, 0.0500000007, 0.0500000007
     60,  0.100000001,           0., 0.0500000007
     61,  0.100000001,  0.100000001,           0.
     62,  0.100000001, 0.0500000007,           0.
     63,  0.100000001,           0.,           0.
     64, 0.0500000007,  0.100000001,           1.
     65, 0.0500000007, 0.0500000007,           1.
     66, 0.0500000007,           0.,           1.
     67, 0.0500000007,  0.100000001,  0.949999988
     68, 0.0500000007, 0.0500000007,  0.949999988
     69, 0.0500000007,           0.,  0.949999988
     70, 0.0500000007,  0.100000001,  0.899999976
     71, 0.0500000007, 0.0500000007,  0.899999976
     72, 0.0500000007,           0.,  0.899999976
     73, 0.0500000007,  0.100000001,  0.850000024
     74, 0.0500000007, 0.0500000007,  0.850000024
     75, 0.0500000007,           0.,  0.850000024
     76, 0.0500000007,  0.100000001,  0.800000012
     77, 0.0500000007, 0.0500000007,  0.800000012
     78, 0.0500000007,           0.,  0.800000012
     79, 0.0500000007,  0.100000001,         0.75
     80, 0.0500000007, 0.0500000007,         0.75
     81, 0.0500000007,           0.,         0.75
     82, 0.0500000007,  0.100000001,  0.699999988
     83, 0.0500000007, 0.0500000007,  0.699999988
     84, 0.0500000007,           0.,  0.699999988
     85, 0.0500000007,  0.100000001,  0.649999976
     86, 0.0500000007, 0.0500000007,  0.649999976
     87, 0.0500000007,           0.,  0.649999976
     88, 0.0500000007,  0.100000001,  0.600000024
     89, 0.0500000007, 0.0500000007,  0.600000024
     90, 0.0500000007,           0.,  0.600000024
     91, 0.0500000007,  0.100000001,  0.550000012
     92, 0.0500000007, 0.0500000007,  0.550000012
     93, 0.0500000007,           0.,  0.550000012
     94, 0.0500000007,  0.100000001,          0.5
     95, 0.0500000007, 0.0500000007,          0.5
     96, 0.0500000007,           0.,          0.5
     97, 0.0500000007,  0.100000001,  0.449999988
     98, 0.0500000007, 0.0500000007,  0.449999988
     99, 0.0500000007,           0.,  0.449999988
    100, 0.0500000007,  0.100000001,  0.400000006
    101, 0.0500000007, 0.0500000007,  0.400000006
    102, 0.0500000007,           0.,  0.400000006
    103, 0.0500000007,  0.100000001,  0.349999994
    104, 0.0500000007, 0.0500000007,  0.349999994
    105, 0.0500000007,           0.,  0.349999994
    106, 0.0500000007,  0.100000001,  0.300000012
    107, 0.0500000007, 0.0500000007,  0.300000012
    108, 0.0500000007,           0.,  0.300000012
    109, 0.0500000007,  0.100000001,         0.25
    110, 0.0500000007, 0.0500000007,         0.25
    111, 0.0500000007,           0.,         0.25
    112, 0.0500000007,  0.100000001,  0.200000003
    113, 0.0500000007, 0.0500000007,  0.200000003
    114, 0.0500000007,           0.,  0.200000003
    115, 0.0500000007,  0.100000001,  0.150000006
    116, 0.0500000007, 0.0500000007,  0.150000006
    117, 0.0500000007,           0.,  0.150000006
    118, 0.0500000007,  0.100000001,  0.100000001
    119, 0.0500000007, 0.0500000007,  0.100000001
    120, 0.0500000007,           0.,  0.100000001
    121, 0.0500000007,  0.100000001, 0.0500000007
    122, 0.0500000007, 0.0500000007, 0.0500000007
    123, 0.0500000007,           0., 0.0500000007
    124, 0.0500000007,  0.100000001,           0.
    125, 0.0500000007, 0.0500000007,           0.
    126, 0.0500000007,           0.,           0.
    127,           0.,  0.100000001,           1.
    128,           0., 0.0500000007,           1.
    129,           0.,           0.,           1.
    130,           0.,  0.100000001,  0.949999988
    131,           0., 0.0500000007,  0.949999988
    132,           0.,           0.,  0.949999988
    133,           0.,  0.100000001,  0.899999976
    134,           0., 0.0500000007,  0.899999976
    135,           0.,           0.,  0.899999976
    136,           0.,  0.100000001,  0.850000024
    137,           0., 0.0500000007,  0.850000024
    138,           0.,           0.,  0.850000024
    139,           0.,  0.100000001,  0.800000012
    140,           0., 0.0500000007,  0.800000012
    141,           0.,           0.,  0.800000012
    142,           0.,  0.100000001,         0.75
    143,           0., 0.0500000007,         0.75
    144,           0.,           0.,         0.75
    145,           0.,  0.100000001,  0.699999988
    146,           0., 0.0500000007,  0.699999988
    147,           0.,           0.,  0.699999988
    148,           0.,  0.100000001,  0.649999976
    149,           0., 0.0500000007,  0.649999976
    150,           0.,           0.,  0.649999976
    151,           0.,  0.100000001,  0.600000024
    152,           0., 0.0500000007,  0.600000024
    153,           0.,           0.,  0.600000024
    154,           0.,  0.100000001,  0.550000012
    155,           0., 0.0500000007,  0.550000012
    156,           0.,           0.,  0.550000012
    157,           0.,  0.100000001,          0.5
    158,           0., 0.0500000007,          0.5
    159,           0.,           0.,          0.5
    160,           0.,  0.100000001,  0.449999988
    161,           0., 0.0500000007,  0.449999988
    162,           0.,           0.,  0.449999988
    163,           0.,  0.100000001,  0.400000006
    164,           0., 0.0500000007,  0.400000006
    165,           0.,           0.,  0.400000006
    166,           0.,  0.100000001,  0.349999994
    167,           0., 0.0500000007,  0.349999994
    168,           0.,           0.,  0.349999994
    169,           0.,  0.100000001,  0.300000012
    170,           0., 0.0500000007,  0.300000012
    171,           0.,           0.,  0.300000012
    172,           0.,  0.100000001,         0.25
    173,           0., 0.0500000007,         0.25
    174,           0.,           0.,         0.25
    175,           0.,  0.100000001,  0.200000003
    176,           0., 0.0500000007,  0.200000003
    177,           0.,           0.,  0.200000003
    178,           0.,  0.100000001,  0.150000006
    179,           0., 0.0500000007,  0.150000006
    180,           0.,           0.,  0.150000006
    181,           0.,  0.100000001,  0.100000001
    182,           0., 0.0500000007,  0.100000001
    183,           0.,           0.,  0.100000001
    184,           0.,  0.100000001, 0.0500000007
    185,           0., 0.0500000007, 0.0500000007
    186,           0.,           0., 0.0500000007
    187,           0.,  0.100000001,           0.
    188,           0., 0.0500000007,           0.
    189,           0.,           0.,           0.
*Element, type=C3D8
 1,  64,  65,  68,  67,   1,   2,   5,   4
 2,  65,  66,  69,  68,   2,   3,   6,   5
 3,  67,  68,  71,  70,   4,   5,   8,   7
 4,  68,  69,  72,  71,   5,   6,   9,   8
 5,  70,  71,  74,  73,   7,   8,  11,  10
 6,  71,  72,  75,  74,   8,   9,  12,  11
 7,  73,  74,  77,  76,  10,  11,  14,  13
 8,  74,  75,  78,  77,  11,  12,  15,  14
 9,  76,  77,  80,  79,  13,  14,  17,  16
10,  77,  78,  81,  80,  14,  15,  18,  17
11,  79,  80,  83,  82,  16,  17,  20,  19
12,  80,  81,  84,  83,  17,  18,  21,  20
13,  82,  83,  86,  85,  19,  20,  23,  22
14,  83,  84,  87,  86,  20,  21,  24,  23
15,  85,  86,  89,  88,  22,  23,  26,  25
16,  86,  87,  90,  89,  23,  24,  27,  26
17,  88,  89,  92,  91,  25,  26,  29,  28
18,  89,  90,  93,  92,  26,  27,  30,  29
19,  91,  92,  95,  94,  28,  29,  32,  31
20,  92,  93,  96,  95,  29,  30,  33,  32
21,  94,  95,  98,  97,  31,  32,  35,  34
22,  95,  96,  99,  98,  32,  33,  36,  35
23,  97,  98, 101, 100,  34,  35,  38,  37
24,  98,  99, 102, 101,  35,  36,  39,  38
25, 100, 101, 104, 103,  37,  38,  41,  40
26, 101, 102, 105, 104,  38,  39,  42,  41
27, 103, 104, 107, 106,  40,  41,  44,  43
28, 104, 105, 108, 107,  41,  42,  45,  44
29, 106, 107, 110, 109,  43,  44,  47,  46
30, 107, 108, 111, 110,  44,  45,  48,  47
31, 109, 110, 113, 112,  46,  47,  50,  49
32, 110, 111, 114, 113,  47,  48,  51,  50
33, 112, 113, 116, 115,  49,  50,  53,  52
34, 113, 114, 117, 116,  50,  51,  54,  53
35, 115, 116, 119, 118,  52,  53,  56,  55
36, 116, 117, 120, 119,  53,  54,  57,  56
37, 118, 119, 122, 121,  55,  56,  59,  58
38, 119, 120, 123, 122,  56,  57,  60,  59
39, 121, 122, 125, 124,  58,  59,  62,  61
40, 122, 123, 126, 125,  59,  60,  63,  62
41, 127, 128, 131, 130,  64,  65,  68,  67
42, 128, 129, 132, 131,  65,  66,  69,  68
43, 130, 131, 134, 133,  67,  68,  71,  70
44, 131, 132, 135, 134,  68,  69,  72,  71
45, 133, 134, 137, 136,  70,  71,  74,  73
46, 134, 135, 138, 137,  71,  72,  75,  74
47, 136, 137, 140, 139,  73,  74,  77,  76
48, 137, 138, 141, 140,  74,  75,  78,  77
49, 139, 140, 143, 142,  76,  77,  80,  79
50, 140, 141, 144, 143,  77,  78,  81,  80
51, 142, 143, 146, 145,  79,  80,  83,  82
52, 143, 144, 147, 146,  80,  81,  84,  83
53, 145, 146, 149, 148,  82,  83,  86,  85
54, 146, 147, 150, 149,  83,  84,  87,  86
55, 148, 149, 152, 151,  85,  86,  89,  88
56, 149, 150, 153, 152,  86,  87,  90,  89
57, 151, 152, 155, 154,  88,  89,  92,  91
58, 152, 153, 156, 155,  89,  90,  93,  92
59, 154, 155, 158, 157,  91,  92,  95,  94
60, 155, 156, 159, 158,  92,  93,  96,  95
61, 157, 158, 161, 160,  94,  95,  98,  97
62, 158, 159, 162, 161,  95,  96,  99,  98
63, 160, 161, 164, 163,  97,  98, 101, 100
64, 161, 162, 165, 164,  98,  99, 102, 101
65, 163, 164, 167, 166, 100, 101, 104, 103
66, 164, 165, 168, 167, 101, 102, 105, 104
67, 166, 167, 170, 169, 103, 104, 107, 106
68, 167, 168, 171, 170, 104, 105, 108, 107
69, 169, 170, 173, 172, 106, 107, 110, 109
70, 170, 171, 174, 173, 107, 108, 111, 110
71, 172, 173, 176, 175, 109, 110, 113, 112
72, 173, 174, 177, 176, 110, 111, 114, 113
73, 175, 176, 179, 178, 112, 113, 116, 115
74, 176, 177, 180, 179, 113, 114, 117, 116
75, 178, 179, 182, 181, 115, 116, 119, 118
76, 179, 180, 183, 182, 116, 117, 120, 119
77, 181, 182, 185, 184, 118, 119, 122, 121
78, 182, 183, 186, 185, 119, 120, 123, 122
79, 184, 185, 188, 187, 121, 122, 125, 124
80, 185, 186, 189, 188, 122, 123, 126, 125
*Nset, nset=<node-set>, generate
   1,  189,    1
*Elset, elset=<element-set>, generate
  1,  80,   1
*Solid Section, elset=<element-set>, material=<material>
*End Part
*Assembly, name=<name>
*Instance, name=<instance>, part=<part>
*End Instance
*Nset, nset=<node-set>, instance=<instance>
  61,  62,  63, 124, 125, 126, 187, 188, 189
*Elset, elset=<element-set>, instance=<instance>
 39, 40, 79, 80
 127,
*End Assembly
*Psd-definition, name=<name>, g=9.81, type=BASE
0.01, 0., 10.
0.01, 0., 2000.
*Spectrum, name=<name>, type=ACCELERATION
20., 10., 0.02
200., 100., 0.02
200., 600., 0.02
60., 2000., 0.02
*Material, name=<material>
*Density
8000.,
*Elastic
 2e+11,0.
*Boundary
<node-set>, ENCASTRE
*Step, name=<step>, nlgeom=NO, perturbation
*Frequency, eigensolver=Lanczos, sim=NO, acoustic coupling=on, normalization=mass
20, , , , ,
*Restart, write, frequency=0
*Output, field
*Node Output, variable=PRESELECT
*Element Output, directions=YES
S,
*End Step
*Random Response
10., 2000., 20, 3.,
*Modal Damping, definition=FREQUENCY RANGE
10., 0.02
2000., 0.02
*Base Motion, type=ACCELERATION, dof=2, scale=1., load case=1
*Correlation, type=CORRELATED, psd=base-psd, complex=NO
1, 1.
*Output, field
*Node Output
RU, U
RMISES, RS
*Output, history, frequency=0
*End Step
*Response Spectrum, sum=SRSS
shock-spectrum,0., 1., 0., 1.
10., 0.02
2000., 0.02
*Output, field
*Node Output
U,
S,
*End Step
10.3 Download artifacts
10.3.1 Geometry CAD files
No separate CAD file is required for this problem; the geometry is fully defined in the Abaqus/CAE journal files.
10.3.2 Abaqus/CAE journal files
2 generated Abaqus/CAE journals are available.
Show 2 individual journals
10.4 Provenance
Parameter Value
Evidence type Numerical verification
CTest result Passed (Release)
Verification result Passed — 4/4 enforced criteria passed
Test date 04-Nov-2026 19:40:38
Operating system Ubuntu 24.04.5 LTS
Coreform IGA version 2026.11+72575
Source revision e48e5098b2f8
Abaqus version Abaqus Unofficial Packaging Version
Parameter Value
Test date 04-Nov-2026 19:40:57
