NAFEMS P18 T1: membrane with a circular hot spot
1 Objective
Verify the stress produced by the discontinuous thermal strain in Test T1 of The Standard NAFEMS Benchmarks [1]. The automated study compares an immersed Coreform/Abaqus IGA discretization with the published solution.
2 Geometry
Two symmetry planes reduce the \(20\ \text{mm} \times 20\ \text{mm}\) membrane to the \(10\ \text{mm} \times 10\ \text{mm} \times 0.25\ \text{mm}\) quarter model in Figure 1. The quarter-circle of radius \(1\ \text{mm}\) is a second material region, not a hole. Point D lies at \((x,y)=(1,0)\ \text{mm}\) on the interface.
Figure 1: Quarter-symmetry model for NAFEMS P18 T1.
3 Material
Both regions are isotropic and linear elastic with \(E=100{,}000\ \text{MPa}\) and \(\nu=0.3\). The circular region receives a uniform thermal strain of \(1\times10^{-3}\), while the surrounding membrane has zero thermal strain.
Symmetry conditions impose \(u_x=0\) on \(x=0\) and \(u_y=0\) on \(y=0\). The two cells belong to one multi-cell part and use different Abaqus material sections, so the thermal expansion changes discontinuously while displacement remains continuous. The reported \(\sigma_{yy}\) is sampled at D on the surrounding-material side.
5 Mesh & discretization
The immersed model uses a linear, \(C^0\) spline space constructed from a uniform \(44\times44\times1\) background grid. The in-plane cell size is \(0.227\ \text{mm}\), and no local or hierarchical refinement is used. The three-dimensional formulation constrains \(u_z\) and applies the constitutive transformation required to reproduce plane stress.
Figure 2: Exact background grid used for both immersed material regions.
The accepted value is \(\sigma_{yy}(D)=50.0\ \text{MPa}\) [1]. The Coreform IGA test enforces a 4% relative-error limit.
7 Results
7.1 Stress at point D
Table 1: NAFEMS P18 T1 verification results.
Discretization \(\sigma_{yy}(D)\) (MPa) Relative error Limit
Immersed Coreform/Abaqus IGA 48.503 2.99% 4%
Figure 3: Immersed Coreform/Abaqus IGA stress field near the circular interface.
8 Discussion
The immersed result satisfies the accepted value and verifies displacement continuity across the multi-cell material interface together with the discontinuous thermal-strain assignment.
References
[1]
The standard NAFEMS benchmarks. NAFEMS.
Appendix
8.1 Download artifacts
8.1.1 Geometry CAD files
8.1.2 Abaqus/CAE journal files
1 generated Abaqus/CAE journal is available.
Show 1 individual journal
8.2 Provenance
The record below identifies the Coreform/Abaqus verification evidence used by this page.
Parameter Value
Evidence type Numerical verification
CTest result Passed (Release)
Verification result Passed — 1/1 enforced criterion passed
Test date 04-Nov-2026 19:21:12
Operating system Ubuntu 24.04.5 LTS
Coreform IGA version 2026.11+72575
Source revision e48e5098b2f8
Abaqus version Abaqus 6.26-4
