Implicit-dynamic vibration of a three-dimensional beam
1 Objective
Verify direct implicit-dynamic time integration for native Abaqus, body-fitted Coreform IGA, and immersed Coreform IGA discretizations. The six-case study exercises both the TRANSIENT_FIDELITY and MODERATE_DISSIPATION Abaqus application shortcuts [1].
2 Geometry
The model is a rod of length \(L=10\) aligned with the \(x\) axis and a \(2\times2\) square cross-section.
Figure 1: Vibrating-beam geometry and boundary conditions.
3 Material
The rod is linear elastic with Young’s modulus \(E=1\times10^6\), density \(\rho=1\times10^{-6}\), and Poisson’s ratio \(\nu=0\) in a dimensionally consistent unit system. The zero Poisson’s ratio makes the response effectively one-dimensional.
The \(-x\) face is fixed, and the lateral faces are free. A pressure on the \(+x\) face rises smoothly from zero to its peak during one analytical fundamental-mode period, returns smoothly to zero during the next period, and then remains zero. The free-vibration comparison starts after the load has been removed.
5 Mesh & discretization
The native reference uses structured C3D8R elements with nominal size \(h=1\). Both Coreform IGA discretizations use quadratic, \(C^1\) splines with the same nominal size; one is body-fitted and the other is immersed.
Figure 2: Background mesh used by the immersed Coreform IGA model.
All cases cover \(0\leq t\leq2\times10^{-3}\) with an initial increment of \(1\times10^{-6}\) and a maximum increment of \(2\times10^{-6}\). Axial displacement, velocity, and acceleration are recorded at every accepted increment and averaged over the free end.
The fundamental axial frequency of a fixed-free rod is
\[ f_1=\frac{1}{4L}\sqrt{\frac{E}{\rho}}=25{,}000. \]
Each case must predict \(f_1\) within 2%. Each Coreform IGA history is also compared with the native Abaqus history using the same application shortcut.
Quantity Acceptance criterion
Fundamental-frequency relative error \(<0.02\)
Normalized displacement-history RMS error \(<0.01\)
Free-vibration phase RMS error \(<0.2\ \text{rad}\)
Amplitude-decay-ratio difference \(<0.03\)
Energy-decay-ratio difference \(<0.05\)
Accepted-increment count ratio \(\leq1.10\)
Samples per fundamental-mode period \(\geq19.9\)
7 Results
7.1 Fundamental frequency
Table 1: Implicit-dynamic vibrating-beam verification results.
Application Discretization \(f_1\) Relative error Accepted increments
TRANSIENT_FIDELITY Native Abaqus 24745.6 1.02% 1003
TRANSIENT_FIDELITY Body-fitted Coreform IGA 24768.6 0.93% 1003
TRANSIENT_FIDELITY Immersed Coreform IGA 24766.8 0.93% 1003
MODERATE_DISSIPATION Native Abaqus 24681.0 1.28% 1002
MODERATE_DISSIPATION Body-fitted Coreform IGA 24703.8 1.18% 1002
MODERATE_DISSIPATION Immersed Coreform IGA 24702.1 1.19% 1002
The maximum normalized displacement-history RMS error is \(2.21\times10^{-3}\), and the maximum free-vibration phase RMS error is \(0.155\ \text{rad}\). The maximum amplitude- and energy-decay-ratio differences are \(304\times10^{-6}\) and \(1.11\times10^{-3}\), respectively.
7.2 Representative displacement field
The final recorded TRANSIENT_FIDELITY immersed result is shown using the same CTest result database that supplies the verification evidence.
Figure 3: Axial displacement in the immersed Coreform IGA vibrating-beam model.
8 Discussion
Every spatial discretization and application shortcut predicts the analytical fundamental frequency within the enforced tolerance. The body-fitted and immersed histories track their matching native Abaqus references without using more accepted increments. The sampling criterion confirms that agreement is not obtained by taking substantially smaller time increments.
References
[1]
Abaqus analysis guide, 2026 FD03. Dassault Systèmes, 2026.
Appendix
8.1 Download artifacts
8.1.1 Geometry CAD files
8.1.2 Abaqus/CAE journal files
6 generated Abaqus/CAE journals are available.
Show 6 individual journals
8.2 Provenance
The records below identify the six simulation CTests and their cross-case study CTest.
Parameter Value
Evidence type Numerical verification
CTest result Passed (Release)
Verification result Passed — 1/1 enforced criterion passed
Test date 04-Nov-2026 19:40:15
Operating system Ubuntu 24.04.5 LTS
Coreform IGA version 2026.11+72575
Source revision e48e5098b2f8
Abaqus version Abaqus 6.26-4
Parameter Value
Test date 04-Nov-2026 19:15:30
Parameter Value
Test date 04-Nov-2026 19:16:49
Parameter Value
Test date 04-Nov-2026 19:17:40
Parameter Value
Test date 04-Nov-2026 19:17:24
Parameter Value
Test date 04-Nov-2026 19:16:21
Parameter Value
Verification result Passed — 26/26 enforced criteria passed
Test date 04-Nov-2026 19:41:04
